timing
Old May 7, 2006 | 02:14 AM
robzlrclub93's Avatar
Default timing
i was wondering , do i really need the timing tool , or has someone figured out a trick to do the timing marks on the cam shaft with out the tool?
Old May 7, 2006 | 02:21 AM
AudiTech04's Avatar
Default RE: timing
Yeah you need one, dont be a cheap A**, im sure you can rent them
Old May 7, 2006 | 03:18 PM
onepoint8tee's Avatar
Default RE: timing
if you have a 2.8 then its a good idea, if its 1.8, dont worry about it...
Old May 8, 2006 | 01:20 AM
dankhound's Avatar
Default RE: timing
The holes all need to line up in the same plane. I believe the larger ones face towards the inside of the engine. The problem is if your off youll do major engine damage. Were talking thousands of dolars here. It can be done without it but it doesnt make sense.
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
B72.0tsline
B7 Models
Mar 3, 2009 01:18 PM
Jessie2k
Aug 5, 2008 01:39 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
