Timing belt
Old Jan 14, 2008 | 06:16 PM
1.8TK3MP's Avatar
Default Timing belt
im going to replace my timing belt.
im wondering if you know of any write ups or any ways to do it without removing the whole front end...b/c i did just install my fmic a month back which will make the install harder if i have to take the whole front end off.
where can i get the kit for cheap and do you recomend a light-weight crank pulley?
how hard is this to do?
Old Jan 14, 2008 | 06:45 PM
chaos92287's Avatar
Default RE: Timing belt
ORIGINAL: 1.8TK3MP
im wondering if you know of any write ups or any ways to do it without removing the whole front end...b/c i did just install my fmic a month back which will make the install harder if i have to take the whole front end off. you dont have to remove the radiator and a/c condensor but it makes it easier cause you have more room.
purems is the cheapest. and NO on the lightweight pulley
how hard is this to do? not hard at all, just time consuming
Old Jan 14, 2008 | 06:52 PM
CRAZYHAWK's Avatar
Check
www.audiworld.com
Tech Articles
Old Jan 14, 2008 | 06:57 PM
1.8TK3MP's Avatar
thanks.... and i was thinking about goin with the lightweight crank pulley...what would you say?...would there be any gains?..
what about a lighweight camgear?
Old Jan 14, 2008 | 07:02 PM
chaos92287's Avatar
no, lightweight pulley adds no gains and makes your engine less reliable. it is pointless.
Old Jan 14, 2008 | 07:04 PM
1.8TK3MP's Avatar
i thought they were proven to add gains?
Old Jan 14, 2008 | 07:05 PM
1.8TK3MP's Avatar
also i am replacing my valve cover gasket tomorrow... but idk if i need the cam seals or if it comes in the kit...??
Old Jan 14, 2008 | 07:06 PM
ImTheDevil's Avatar
Cam seals should come in the timing belt kit. You won't be able to do them while just doing the valve cover gaskets though - the cam gears have to come off to access the gaskets - that's a job to tackle during the t-belt service.
Old Jan 14, 2008 | 07:10 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: 1.8TK3MP
engine should rev faster, but no real hp gains. Gains arent really worth the cost/effort
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
TheBat
Jun 20, 2008 01:14 PM
