Timing belt. Updated with pics
Old Apr 19, 2007 | 03:22 PM
  #21
zoti's Avatar
Default RE: Timing belt
Pull the upper cover off. It's held in place by 2 clips but you will need to move the hose that goes in front of it out of the way.
Old Apr 19, 2007 | 03:26 PM
  #22
new2me's Avatar
ORIGINAL: Cruz734
"you could pull the front off and check out the T-belt"
Pull the front what off? Sorry I'm not very mechanicly inclined. My dads a heavy engine mechanic so I'll work with him. Thanks for the tip.
sdboarder, Sorry to intrude on your thread with my problem
1 thread = 2 helped for same thing.
The front bumper assembly has to come off to do any kind of work on the front of the motor. It sounds worse than it really is so dont be discouraged. I should also add that since summer's coming, this is a great opportunity to do a coolant flush.
Old Apr 19, 2007 | 03:28 PM
  #23
zoti's Avatar
If you get the timing belt kit from dieselgeeks.com then it will come with 2 bolts which you put on and they enable you to just pull the radiator bracket away from the engine to do the job. This way there are less wires to disconnect.
Old Apr 19, 2007 | 04:10 PM
  #24
akielb's Avatar
hey zoti - how long do you think those bolts are? - I picked up the ECS ultimate kit and they don't supply those - I found some 120mm at my work - thats 4.5 inches. would I need longer one's?
Old Apr 19, 2007 | 05:59 PM
  #25
zoti's Avatar
As long as the thread on those bolts fitI think you are going to be ok. I think that is about the lenght of the bolts I got. You only need 3-4 inches of clearence and it will save you from disconnecting all the wires that go through the radiator frame.
Old Apr 20, 2007 | 12:38 AM
  #26
sdboarder84's Avatar
what is the differance between the "new" and"old" design?
Old Apr 20, 2007 | 02:44 PM
  #27
Default RE: Timing belt. Updated with pics
What do you guys think?
Crummy
Jan 24, 2012 07:49 AM
audi_tt_4u
Sep 16, 2009 07:27 PM
Hoguenstein
Jan 16, 2009 11:45 PM
syxxty
May 22, 2008 02:23 PM
