timing, water, ac belt quote - is this good?
Old Jul 25, 2007 | 07:59 PM
fritz's Avatar
Default timing, water, ac belt quote - is this good?
i got a quote from a reputable shop, what do you guys think???
[IMG]local://upfiles/3385/F071809D675D46768FC9486617C369F0.jpg[/IMG]
Old Jul 25, 2007 | 08:05 PM
99A4NOW's Avatar
Default RE: timing, water, ac belt quote - is this good?
They didn't seperate out the labor but I suspect it is about $450 so that sounds about right. I did mine myself, got a kit that included all those parts for under $300 and my labor was basically free.
Old Jul 25, 2007 | 08:08 PM
fritz's Avatar
is this something that can be a do it yourselfer? - i mean replacing all of thees things and what did you use to go off of?
Old Jul 25, 2007 | 08:15 PM
akielb's Avatar
just take a look http://www.audiworld.com/tech/eng35.shtml its not that difficult just very time consuming
http://www.audidiy.com/b5a4.html is your friend
Old Jul 25, 2007 | 08:18 PM
99A4NOW's Avatar
I have a fair amount of mechanical ability since most of my life I've owned really crappy cars that always needed fixed. With a good understanding of what everything does and a good supply of basic tools anyone could probably do this. Here is a write up I used as a guide- it was very helpful.
It's really just more time consuming than it is difficult. My difficulty rested mostly with some coolant leaks I had previous to the belt change and I still haven't got them all sorted out- but you won't really run into that if you're just doing the standard t-belt/water pump/t-stat change. I highly recommend upgrading the DV while you have it apart that much, if you're going to do this youself or even if you decideto have someone else do it.
Read the write up a few times and ask lots of questions on the forums if you dont' understang things
Old Jul 25, 2007 | 08:27 PM
fritz's Avatar
i am looking at this for the timing belt kit from ecs tuning... itll come with these:
With the great success of our early version 1.8T Timing Belt Kit ECS has decided to offer a more complete kit with everything customers usually order when replacing their timing belt. Kit includes the following: [*]Timing Belt[*]OE UpdatedTensioner[*]OE Tensioner Roller[*]OE Idler Roller[*]Hepu Metal OE Water Pump (half) with gasket[*]Behr OEThermostat with O-ring[*]Conti-Tech A/C Belt[*]Conti-Tech P/S Belt[*]Conti-Tech Alternator Belt[*]2) 1.5 Liter bottles of G12 Coolant[/align]all for 270, am i missing anything else?
Old Jul 25, 2007 | 08:47 PM
akielb's Avatar
Thats what I purchased - I would also suggest doing your Cam seals while you are in there - 20 min beyond more work.
Old Jul 25, 2007 | 08:50 PM
fritz's Avatar
hwo long should the whole procedure take?
Old Jul 25, 2007 | 08:54 PM
akielb's Avatar
non-stop with no major problems(broken bolts or some crap like that) or runs to the store for a tool. I would say first time, with minimal mechanical knowledge(going very slow) many 8-10 hours. took me 10-12 the first time with a couple runs to the store, lunch, and not workin hard. If I did it again - could do it in 3-4 hours
Old Jul 25, 2007 | 09:04 PM
fritz's Avatar
would yo umind linking me to the correct seals from ecs tuning???
cantdrive55
Dec 16, 2015 05:56 PM
skatemerica155
Aug 31, 2007 11:46 AM
diamondzen
Jun 1, 2005 08:01 PM
