Tip tranny fluid change
ORIGINAL: brrman
I think I did mine at 85K and I noticed a slight difference, nothing major though.
But that car was an auto, not sure what you have. Manuals should have a larger degree of noticable difference.
ORIGINAL: onepoint8tee
Thanks.. So you think at 74k miles i should notice a difference?
ORIGINAL: brrman
Just drain and replace. Thats all you need.
ORIGINAL: black b5
i removed the pan and replaced the filter on mine before i installed the PES T-28 kit.
refilled with 5 liters of fluid and it improved my cold weather and shift performance.
i agree that higher mileage transmissions should just drain and fill
Sorry for the repeat posts but.. When go to fill it back up, should i just measure how much i took out, and put that much back in of the new fluid? Is there some kind of tool i need to fill? Can i literaly just drain and fill it ? Should the fluid go up to the hole, like when i stick my finger in there, and i feel fluid, its full? Thanks.
how do you get away with having a T-28 kit with an auto? Isnt that too much power?
ORIGINAL: black b5
no problems as of yet. huge gains over the K04.
there have been others that have BT setups on tip transmission without any troubles
ORIGINAL: black991.8tq
i changed mine just over 100k and it was like someone took out the pos that was slipping and replaced it with a new trans. it is very worth it to change.
