Tip tranny fluid change
Old Jan 31, 2006 | 04:22 PM
onepoint8tee's Avatar
Default RE: Tip tranny fluid change
ORIGINAL: brrman
ORIGINAL: onepoint8tee
ORIGINAL: brrman
Just drain and replace. Thats all you need.
Thanks.. So you think at 74k miles i should notice a difference?
I think I did mine at 85K and I noticed a slight difference, nothing major though.
But that car was an auto, not sure what you have. Manuals should have a larger degree of noticable difference.
Thanks.. The "Tip tranny" part of the subject didtn give it away that its an auto???
Old Jan 31, 2006 | 04:25 PM
ORIGINAL: black b5
i removed the pan and replaced the filter on mine before i installed the PES T-28 kit.
refilled with 5 liters of fluid and it improved my cold weather and shift performance.
i agree that higher mileage transmissions should just drain and fill
how do you get away with having a T-28 kit with an auto? Isnt that too much power?
Old Jan 31, 2006 | 04:30 PM
Sorry for the repeat posts but.. When go to fill it back up, should i just measure how much i took out, and put that much back in of the new fluid? Is there some kind of tool i need to fill? Can i literaly just drain and fill it ? Should the fluid go up to the hole, like when i stick my finger in there, and i feel fluid, its full? Thanks.
Old Jan 31, 2006 | 04:31 PM
Kobe Diesel's Avatar
I only know of two types of transmissions
Manual
Auto
Tip can = advice (which is what I thought the thread was indicating)
I guess Tip = tiptronic = too fancy for me!
Old Jan 31, 2006 | 04:32 PM
CRAZYHAWK's Avatar
TIPs don't have dipsticks.
Old Jan 31, 2006 | 04:40 PM
No dipstick? Wow, like I said tip = too fancy for me!
Old Jan 31, 2006 | 07:54 PM
black b5's Avatar
ORIGINAL: black b5
no problems as of yet. huge gains over the K04.
there have been others that have BT setups on tip transmission without any troubles
Old Jan 31, 2006 | 08:01 PM
  #18
black991.8tq's Avatar
i changed mine just over 100k and it was like someone took out the pos that was slipping and replaced it with a new trans. it is very worth it to change.
Old Jan 31, 2006 | 08:02 PM
  #19
ORIGINAL: black991.8tq
Did you do the filter?
Old Jan 31, 2006 | 08:06 PM
  #20
i had it done at dubwerks, im pretty sure they did the filter
