tip tronic help (have fault codes)
Old Apr 25, 2007 | 01:22 AM
eurokid's Avatar
Default RE: tip tronic help plz
ORIGINAL: scotts custom
when i went to my audi dealer to ask questions why my tip is not working, the first question the guy asked me is if the gears themselves were lit up or all the gears at one time were lit just like yours. so im guessing that it is a common thing and it can be fixed easily
yeah i'm hopin nothin big is wrong...and i see no reason why there would be considering it just happened and there has been nothing to lead up to this.
But it's not just the tip, it does tthe same thing in just regular drive (D)
Old Apr 25, 2007 | 01:24 AM
scotts custom's Avatar
o i guess i didnt make myself that clear. he asked me when it lights up in D and in Tip
Old Apr 25, 2007 | 01:26 AM
onepoint8tee's Avatar
ORIGINAL: eurokid
so just tinkering with it and seeing what rebooting the system would do is a bad thing?
There is no point. Getting the fault codes is step 1. You have a CEL so there are fault codes. There's no point in tinkering with anything when a fault code will instantly point you in the right direction. Its an Audi, not a Dell, so "rebooting" is rarely a solution to an underlying problem.
eurokid's Avatar
well that's good..one problem that is common.. Now i just have to figure out why it wont go into 4th or 5th.
Old Apr 25, 2007 | 01:29 AM
eurokid's Avatar
ORIGINAL: onepoint8tee
well i guess that eliminates my next step, which was a hammer.
Old Apr 25, 2007 | 12:18 PM
CRAZYHAWK's Avatar
He'll have to read the TIP computer. Use a VAG or a Audi code reader.
http://search.ebay.com/search/search...&category0=
Old Apr 25, 2007 | 07:04 PM
eurokid's Avatar
that would indeed be a helpful investment..considering a CEL for our cars isnt all that uncommon..
from what i hear it's the "your car is modded" light
Old May 6, 2007 | 04:06 PM
  #18
eurokid's Avatar
so i know it's been a while, but i just got around to it..
fault codes : P0734
P0717
(not shifting into fourth gear)
Old May 6, 2007 | 07:03 PM
  #19
Jovian's Avatar
P0734 - Gear 4 Incorrect Ratio
P0717 - Input Turbine/Speed Sensor Circ. No Signal
I would look into the Turbine/Speed sensor cuir no signal first. Not sure where its located but make sure its conencted and the connectors are clean. Also follow the line and make sure its not crimped, open or cut.
Old May 6, 2007 | 08:53 PM
  #20
eurokid's Avatar
hey thanx,,yeah i was told that it was some sort of sensor..what do you make of the 4th gear incorrect ratio>?
