tip tronic help (have fault codes)
ORIGINAL: scotts custom
when i went to my audi dealer to ask questions why my tip is not working, the first question the guy asked me is if the gears themselves were lit up or all the gears at one time were lit just like yours. so im guessing that it is a common thing and it can be fixed easily
But it's not just the tip, it does tthe same thing in just regular drive (D)
ORIGINAL: eurokid
so just tinkering with it and seeing what rebooting the system would do is a bad thing?
ORIGINAL: onepoint8tee
There is no point. Getting the fault codes is step 1. You have a CEL so there are fault codes. There's no point in tinkering with anything when a fault code will instantly point you in the right direction. Its an Audi, not a Dell, so "rebooting" is rarely a solution to an underlying problem.
He'll have to read the TIP computer. Use a VAG or a Audi code reader.
http://search.ebay.com/search/search...&category0=
P0734 - Gear 4 Incorrect Ratio
P0717 - Input Turbine/Speed Sensor Circ. No Signal
I would look into the Turbine/Speed sensor cuir no signal first. Not sure where its located but make sure its conencted and the connectors are clean. Also follow the line and make sure its not crimped, open or cut.
