tire pressure
Old Nov 2, 2005 | 12:52 AM
Silver98A4's Avatar
Default tire pressure
before i consult my manual...can anyone tell me off hand what the tire pressure should be on a 98 a4 quattro v6 30valve. i have the 16" wheels.
Old Nov 2, 2005 | 05:44 AM
sandman's Avatar
Default RE: tire pressure
it will say on the side wall of your tire, mine says no more than 40 psi so im just under that. 35psi
Old Nov 2, 2005 | 05:55 AM
russianari's Avatar
sandman's right, you may not be old enough to remember the ford explorer/firestone incident. there was a huge scandal about the tires ripping, explorers flipping, people dying and getting hurt, and other stuff.... so they recommended setting the psi a little below the maximum tire pressure. so, for example, max 45, set it to about 40.
Old Nov 2, 2005 | 06:05 AM
Karl's Avatar
you should also look at the rate the it says for the car.. not just the tires.. i think its on the inside of the gas flap at least it is on mine
Old Nov 2, 2005 | 06:29 AM
sandman's Avatar
ORIGINAL: Redgoat
ahhhhhhh yes good call goat man, mine says 36psi damn im 1 psi under.[:@]
Old Nov 2, 2005 | 06:30 AM
flyboy's Avatar
also look into the tire wear. and adjust accordingly.
Old Nov 2, 2005 | 09:18 AM
david9999's Avatar
For those of you who are relatively new, make sure that you check the pressure when the tires are cold (Ie first thing in the AM), not after they have been drivn. The specified pressure is for cold tires. The pressure rises when the tires are warm and if you set the specified pressure when warm, your tire will be under inflated.
Old Nov 6, 2005 | 04:26 AM
dankhound's Avatar
Never use the tires pressure. Thats just a maximum pressure. There will be a placard in you fuel fill door or one of the door jambs with the proper tire pressure set cold. Usually about 3 or 4 psi higher for hot, but the best way is to set them cold.
pdxrado
Jan 28, 2013 06:35 PM
jojosam
Mar 14, 2011 01:37 PM
zippy_gg
Dec 12, 2008 02:12 PM
Dj Spiel
Nov 16, 2007 02:13 PM
A4hud_
Nov 14, 2004 08:53 PM
