Tire Pressure Sticker Clarification
Old Jul 25, 2006 | 01:38 PM
coolvirus's Avatar
Default Tire Pressure Sticker Clarification
I have a 99 A4 1.8T Quattro, with stock tires. I was reading the tire pressure sticker inside the fuel door and am a little confused about what it says. I searched the forum and found nothing on this. I was wondering if someone can help to clarify it.
The sticker has the following info:
Front
Bar psi kPa
2.1 32 210
2.8 42 280
Rear
Bar psi kPa
2.1 32 210
2.9 42 290
I know what psi is. But what is Bar and kPa and why are the numbers from the front a little different than the rear?
Thank you in advance for any input.
Old Jul 25, 2006 | 01:44 PM
CRAZYHAWK's Avatar
Default RE: Tire Pressure Sticker Clarification
1.013 BAR = 14.69 pounds/square inch
Old Jul 25, 2006 | 03:32 PM
acetrebo's Avatar
Cmon now, their just different measurements.
Like Yards vs. Meters.
Just use the PSI rating that you should be used to.
They are min and max ratings. If I were you, I would run about 37-38 PSI all around.
Old Jul 25, 2006 | 04:41 PM
coolvirus's Avatar
Pardon my ignorance but I actually had not heard of the bar and kPa measurement units. I've always dealt with psi units in the past. But now I know they're all just measuring the same thing.
Thanks for the replies guys.
Old Jul 25, 2006 | 09:41 PM
david9999's Avatar
1 Bar is one atmospheric pressure, =14.6 psi
kPa is kilopascals (metric)
stemiched89
Feb 14, 2014 07:45 PM
pdxrado
Jan 28, 2013 06:35 PM
jojosam
Mar 14, 2011 01:37 PM
LKaler
Apr 17, 2010 12:52 PM
A4hud_
Nov 14, 2004 08:53 PM
