Torque converter
Old Apr 4, 2007 | 12:23 AM
nitram's Avatar
Default Torque converter
Hi
I have just been told I need a torque converter due to eng.light check
code 741. Also found out that once you replace the trans. fluid which
you need to do when changing torque converter, you
can kiss your transmission goodbye within a year so it's best to get
a new transmission from the start. Any help in this matter appreciated. Thanks
Martin 2002 3.0 Avant
Old Apr 4, 2007 | 01:19 AM
Lazer Viking's Avatar
Default RE: Torque converter
i dont know about changing fluid leading to transmission death
where did you hear this ?
Old Apr 4, 2007 | 02:37 PM
ironman's Avatar
Ive actually replaced a torque convertor on one of my cars, it was a Galant not an Audi and i had no issuesi hamered on the car and never had any trouble this is when i knew nutin about cars and didnt car about them. No tranny issues waht so ever, the only thing that i could see happening is if you have a weak tranny all the extra power you will get( going back to stock could hurt your gears) other then that should have no worries.
Old Apr 4, 2007 | 04:14 PM
2k S4's Avatar
Don't worry about it. The theory about it is, that the new fluid will flush out all of the gunk in the trans, and hose the valve body & torque converter. The trans needs to be severally neglected, & have a ton of build up for this to happen. With the high quality synthetics today, it's not an issue.
Old Apr 4, 2007 | 04:20 PM
techbod's Avatar
P0741 = Torque converter clutch ( TCC ) solenoid - performance or stuck off,
problem is Wiring, TCC solenoid
Old Apr 4, 2007 | 10:45 PM
nitram's Avatar
I appreciate all replies
Martin
Old Apr 5, 2007 | 12:26 AM
david9999's Avatar
V.A.G1551 Scan Tool print out
Possible cause
Corrective action
17125 P0741 ATF level not OK Faulty or Wrong converter - Check ATF level Repair Manual, 5 Spd. Automatic Transmission 01V Repair Group 37; ATF-level checking and topping off - Check converter code Clutch for bridging converter no power transfer Pressure control valve 4 -N218- 1) is mechanically faulty Problems in the ATF-line to pressure control valve 4 -N218- 1) Converter pressure valve faulty Torque converter valve faulty Continue - Read measuring value block Page 01-183 ; Display group number 007 2)check clutch TC (closed) and permissible torque converter slip - Replace pressure control valve 4 -N218- or valve body Repair Manual, 5 Spd. Automatic Transmission 01V Repair Group 38; Oil pan, oil strainer and valve body, removing and installing; valve body removing
tambleramble
Mar 23, 2009 06:41 AM
S4sweeteeteeRS
Aug 25, 2008 09:31 PM
bonzo246
B7 Models
Apr 16, 2008 07:45 PM
Avant13
Apr 14, 2008 09:19 PM
craz1469
Feb 9, 2007 03:26 PM
