Torque conveter controlled by a Brake light switch F
Old Mar 10, 2007 | 02:39 PM
kbuff97A4's Avatar
Default Torque conveter controlled by a Brake light switch F
Where is the Brake light switch F located on a 97 A4Q 12V5sp Auto CJP?
Old Oct 14, 2007 | 10:06 PM
SLVR99A4's Avatar
Default RE: Torque conveter controlled by a Brake light switch F
Does anybody have an idea about a faulty brake light switch in relation to the torque converter? Reason being is that I have been experiencing multiple problems with my transmission, shifting related,and alsomalfunctioning cruise controland have ran multiple vagcomscans and the onlyfaults I receive is a faulty brake light switch. I will be replacing this switch to see ifI get expected results.
Old Oct 14, 2007 | 10:18 PM
auditech79's Avatar
The brake light switch won't mess with your torque converter, but it will mess with your cruise control.
Old Oct 14, 2007 | 11:17 PM
SLVR99A4's Avatar
So with a faulty brake light switch that would not trip some sort of limp mode or trigger fowl ecu readings? The reason I am persuing such fault is b/c the last note I made while cruise controlWAS functioningis that the car was performingand operatinggreat. When scanningand clearing the faultwith vagcom car would resume to exceptionalbehavior for awhile only resuming back to it's normal being, shifting quickly,erratic vibrations at idle and hard gear selectionswhen changing gears; (ie. P to D).While driving in tip-mode, transmission reacts and performs great.
Old Oct 15, 2007 | 12:15 AM
auditech79's Avatar
What the brake light switch could do is freak out the brake electronics into engaging the ABS and making the car feel like its shifting wrong. The brake light switch can mask, and cause all kinds of problems so replace it asap.
Old Oct 15, 2007 | 08:04 PM
SLVR99A4's Avatar
Ok guys, tonight I replaced my brake light switch. I cleared my 00526 fault code and took for a test drive only to find the same damn fault code came up again!When installing the new switchI did take notice of another similiar switch right above the one I replaced...??? Itwas white in color rather thanthe black oneIreplaced and led over to my center console, possibly for the gear selector switch? Not sure ifTHIS was the one I wassuppose to replace; not sure what each one is assigned to control either. Regardless Iam now back to square one with the code. All brake lights work fine along with the gear selector; cruise control is stillinoperable. Also, whileI had my lower dash removed I took notice of the bigger fuse block panels to the right of thenormalaccessible fuse panel. I DO NOT have a fuse in the number 72 slot of this larger panel. I am not sure if there is suppose to be one installed or not. If anyonecould check on this it would be greatly appreciated, thanks.
Old Oct 15, 2007 | 08:21 PM
auditech79's Avatar
The brake light switches vary in color, because they keep updating them cause the suck! [:'(]
If your getting the same fault code you broke it, its easy to break em too, techs do it everyday.
Try to take it back to the dealer and tell them the taillights stays on after i installed it and they should give you another one.
Its the switch right above the brake pedal BTW, the one above the clutch pedal isn't the one you need.
Old Oct 15, 2007 | 08:37 PM
SLVR99A4's Avatar
Default RE: Torque converter controlled by a Brake light switch F
I have an automatic; there are two identical sensors located on top of each other. I replaced the lower switch which had a vacuum line running into it. I specifically followed the procedures on installing this bad-designed piece of junk, carefully, so that I would not damage it. Maybe I will replace both of them next.
PennSt8_A4
Nov 28, 2012 09:47 PM
kwathom1
Jan 23, 2011 09:42 PM
brett83
Sep 9, 2010 02:47 PM
Dans99A6
Feb 17, 2010 10:38 PM
betes
Nov 5, 2008 08:27 PM
