Torque or HP
Old Nov 15, 2006 | 08:50 PM
  #21
Bondga's Avatar
Default RE: Torque or HP
Sortof but not quite. unfortunatly with an engine it isn't that cut and dry. you can't have one without the other and there are many ways to create HP from Low torque high Redline to Low redline high Torque. There are also many other factors involved. And as i said before
Holding everything else constant. A car with Higher HP will accelerate faster regardless of it having higher torque.
Old Nov 15, 2006 | 11:42 PM
  #22
Ford2Audi6's Avatar
if you want to look at it in a real world perspective, built honda civics have a lot of hp(no whiplash) but no torque. A diesel truck usually has relatively low hp but a lot of torque(but they can pull houses down.
Old Nov 16, 2006 | 01:59 AM
  #23
AudiCross's Avatar
Bondga:
horse power and torque are direcally praportional, and constant. if a car has 30 foot pounts of torque at 5252 RPM, it MUST HAVE 300 horsepower at 5252 rpm. the reason ricers can have high horsepower and very little torque is becuase they rev verry high. Any RPM above 5252 will have higher horsepower than torque. Muscle cars can have a **** load of torque, and just a lot of HP becuawe they start producing their torque at a very low RPM. Hence them being super fast off the line.
And for the really long complex thing above, here is a simplified version
If something has 20 lbs of torque, basically that means that if you have a bar mounted on an axis, such as the minure or hour hand of a clock, and the bar is 1 foot long, it can turn or stay still with up to 20 pounds on the end. or you cna have a 20 foot bar with 1 pound on the end. That is why having big wheels hurts your acceleration. larder radius (longer bar) means less force on the outside. to deal with that, gear it lower. in an ideal world with no friction and massless gears and wheels, it wouldnt matter. but if you have big wheels, you lose power spinning them, and lower gearing, you lose power form friction of gears and spinninbg them. That is why in a car, the crank horsepower is anywhere from 14 to 21% higher than the wheel horsepower: Friction and kenetic energy (getting something moving)
Old Nov 16, 2006 | 02:05 AM
  #24
Jeff's Avatar
Zombie Defense Force
my car dosent use hp or tq. its all thrust. by that i mean i want a rocket car
Old Nov 16, 2006 | 04:19 PM
  #25
acetrebo's Avatar
ORIGINAL: Jeff
They were showing a rocket car the other day on discovery channel I think. The guy was trying to break the sound barrier and go around 780mph to break the current record.
It was actually an old fighter jet they converted to a wheeled vehicle.
Bet that one has a good butt-dyno result.
Old Nov 16, 2006 | 06:45 PM
  #26
buyfire's Avatar
horsepower for "show" / torque for "go"
  #27
onepoint8tee's Avatar
ORIGINAL: buyfire
huh?
S.d.audi
Sep 5, 2010 07:13 PM
occhis
Apr 30, 2009 09:43 PM
bigern45
Nov 25, 2008 12:44 AM
krystallbluea4
Nov 13, 2008 01:50 PM
cireecnop1
Oct 29, 2005 05:30 PM
