TPS - FULL THROTTLE 76%
Old Apr 28, 2006 | 08:38 PM
RCFerrari's Avatar
Default TPS - FULL THROTTLE 76%
Hello,
My 1999 A4 V6 is only showing 76% at WOT. The reading is from an OBDII monitor while I am pushing on the throttle with my foot.
This may actually be correct but I am looking for some opinions.
Thanks,
Chris
Old Apr 28, 2006 | 08:56 PM
AteUrV8's Avatar
Default RE: TPS - FULL THROTTLE 76%
could this maybe be why ur nitrous isnt performing as well??
Old Apr 29, 2006 | 01:01 AM
RCFerrari's Avatar
It is difficult to say because I am not sure about the dynamics of the TPS % compared to the actual Throttle Body position. That is #1.
#2 is that I am not sure about how the variable INTAKE MANIFOLD plenum may effect nitrous. Since this in not a direct injection, the nitrous must pass through the TB, the IM, down to the cylinder chamber.
I am really hoping someone can tell me about the OBDII % reading at FULL THROTTLE before we begin pulling the intake manifold off the damn car.
Let me know,
Chris
Old Apr 29, 2006 | 02:10 AM
AteUrV8's Avatar
post in the nitrous/turbo forum... you will prob get more knowledgable responses there...ive never had any experience with an OBDII on audis.
Old Apr 29, 2006 | 05:20 PM
dankhound's Avatar
The tps should read about 90% at full throttle.
Old Apr 29, 2006 | 06:40 PM
RCFerrari's Avatar
Thanks for the responses.
The throttle cable is fine... I took apart the underdash and verified that the pedal was pulling on the cable the correct ammount. I got an extra 1% which is nothing worth metioning.
Are there any other adjustments that anyone may suggest. I really don't want to dig to get to the TPS unecessarily.
Are you positive it should be 90% on the V6 30V?
What should idle be? Mine is set at approximatly 3%.
Old Apr 30, 2006 | 12:07 PM
dankhound's Avatar
Every audi ive seen is usually around 90 for wot. Idle is usually anywhere between 3 and 6.
Old Apr 30, 2006 | 01:22 PM
techbod's Avatar
this is the problem when modding you have to take all things into account exhaust/fuel feed & pressure/engine enhancements/lunch times/tyres/wheel sizes/air intakes
explorer686
Nov 15, 2012 11:43 PM
dkg4244
Nov 27, 2007 02:43 PM
Dallas09
Nov 19, 2007 05:16 PM
RCFerrari
Apr 29, 2006 06:37 PM
6cylbiturbo
Apr 6, 2005 06:47 PM
