tranny/clutch issue help
Old Jan 8, 2007 | 05:17 AM
jayson161's Avatar
Default tranny/clutch issue help
two days ago i was driving home, after working on my boost leak issue, i shifted from 2nd to 3rd and when i released the clutch the engine just rev'd and didnt go anywhere. i pulled over and tried all gears and nothing, the clutch isnt engaging. when i push the clutch in it sounds like metal on metal, my friend thinks it can either be the throwout bearing or the clutch fork. i didnt really hear any noises or feel any jerks when it happened.
anybody have an idea on how much it might be to get this looked at, or maybe anything else that could be an issue?
Old Jan 9, 2007 | 01:31 AM
dankhound's Avatar
Default RE: tranny/clutch issue help
In any case your going to have to pull the trans and find the broken part. My bets on a broken pressure plate spring.
Old Jun 17, 2013 | 12:32 PM
mikev310's Avatar
Default throw ut bearing nois
have a4 quarto s 2.0 replaced clutch throw outbearing plates and fly wheel plus bolts it lasted 5 thousand miles then it started to chirp replaced throw out bearing it lasted 2 thousand then started chirp again..pulled out and replaced the entire clutch throw out bearing plates and flywheel a second time....this lasted 4 thousand mile the chirping started again....now just did the bearing again and 2 thousand the chirping started again somebody tell me what the heck is wrong with t
singletrac
Aug 25, 2009 10:47 AM
CoBra03TerminAtoR
May 16, 2008 02:18 AM
skeezo3000
Apr 9, 2008 11:49 PM
skeezo3000
Dec 27, 2007 12:09 AM
STD570
Jul 25, 2006 10:04 PM
