transmission help...
Old Apr 3, 2007 | 04:57 PM
vjmaudi's Avatar
Default transmission help...
After doing some research on Audiforums. I think my inverted gear selector switch is bad. I have the same symptoms as this guy did on thisforum https://www.audiforums.com/m_78103/tm.htm. Anyone know if this repair can be done without taking it to a dealer? Or has anyone done this repair themselves.
Old Apr 3, 2007 | 10:19 PM
TDRILL's Avatar
Default RE: transmission help...
I even looked through the bentley manual for you. I don't see anything called specifically gear selector switch. Unfortunately, they don't have descriptions of what the other sensors control. Perhaps if we knew the correct term as used by the manual I could help you find it and see how difficult it is to replace yourself (if you could get the part).
A few of your options listed:
Automatic transmission control module - in footwell
Multifunction transmission range switch - on left side of tranny housing
Tiptronic switch - down in the shift mechanism
Transmission range selector lever display - in instrument cluster
Hopefully someone else can help you out more. Good luck.
Old Apr 4, 2007 | 11:28 AM
vjmaudi's Avatar
ORIGINAL: TDRILL
Thanks...
larydash
Apr 21, 2014 11:52 AM
A4tun81
Feb 16, 2010 05:45 PM
pattrick02
Jun 24, 2009 06:39 PM
mdeerfield
Dec 18, 2005 10:14 PM
