Transmission Hiccuping
Old Dec 12, 2006 | 06:22 PM
qwho387's Avatar
Default Transmission Hiccuping
Hello all, I searched the threads and did not find anything that was exactly matching my problem.
i have a 97' A4 1.8t Non-Quattro Automatic 155k Miles.
Basically I feel a Hickup in power when i am acellerating and I believe it's the transmission. The enging does not lose power or sound different when it happens.
I would say that it occurs mostly in the lower power band, say 1.5k-2.8k RPM's, and when I am on the highway. It feels like the transmission can't keep up with the engine or something.
I just had some engine work done and was told that the transmission pan was leaking around the seal and I should drop the pan, change the fluid and re-seal it.
Do you guys think that low fluid could create a problem like this or do you think there may be more to the picture?
BTW, I am having the work done anyway @ about $300. Just wondering if I should exect this to solve the problem.
Thanks all!
Old Dec 12, 2006 | 06:33 PM
onepoint8tee's Avatar
Default RE: Transmission Hiccuping
Cant hurt to change the fluid/filter. If its never been done, it would be a great idea to do it. For parts, check out purems.com they have good prices on fluid/filter/gasket and free shipping over $50 i think right now.
Old Dec 12, 2006 | 07:47 PM
qwho387's Avatar
Well I will for sure do the change but do you think low fluid would actually cause a problem like the one I described?
Old Dec 12, 2006 | 07:49 PM
phil872001's Avatar
Yes low tranny fluid can cause all sorts of shifting/slipping/power transfer type problems, i would start there for sure.
Old Sep 24, 2008 | 07:48 PM
DevinA42003's Avatar
I have the same problem and the got the trans fluid replaced. It helped but it sill seems like it slipping a litttle at 1500rpm's.
JackFrost
Nov 19, 2010 08:32 AM
A4tun81
Feb 16, 2010 05:45 PM
pattrick02
Jun 24, 2009 06:39 PM
mdeerfield
Dec 18, 2005 10:14 PM
