Trouble codes...again HELP!
Old Jan 4, 2005 | 05:23 PM
CCGIANTS's Avatar
Default Trouble codes...again HELP!
Well here I am again, have a 98 a4q auto. Pulled a P1432 code, auxilary emission control I believe it said. Any ideas?
Old Jan 4, 2005 | 06:12 PM
Jestnomen's Avatar
6th Gear
Default RE: Trouble codes...again HELP!
Do you have a vag-com or using the autozone method?
Old Jan 4, 2005 | 06:15 PM
CCGIANTS's Avatar
unfortunetly the autozone method. im going to pick up a vag in the next week or so
Old Jan 4, 2005 | 06:34 PM
CCGIANTS's Avatar
Old Jan 9, 2005 | 01:21 AM
CCGIANTS's Avatar
Anybody?
Old Jan 9, 2005 | 04:17 AM
Fieldy's Avatar
Go Jesty Go![8D]
Old Jan 9, 2005 | 04:50 PM
CRAZYHAWK's Avatar
P 1432 Secondary air injection valve open
The ECM operates the secondary air injection pump and opens the vaccum valve to inject fresh air into the exhaust stream , lowering emission levels under certain operating conditions.
Old Jan 9, 2005 | 11:13 PM
CCGIANTS's Avatar
I'm not very mechanically inclined, my apologies, how should I go about taking care of this, more specically, what exactly am I trying to fix?
Old Jan 10, 2005 | 09:10 AM
CRAZYHAWK's Avatar
Find an independent mechanic.
Old Jan 10, 2005 | 10:56 PM
Jestnomen's Avatar
6th Gear
Check the vacuum line running from the exhaust manifold making sure it isn't cracked or not attatched. May want to replace it.
CStites
Dec 20, 2012 12:12 PM
devlzluv
Aug 1, 2010 02:07 PM
Deekster22
Sep 13, 2009 01:22 PM
2000turbo
Nov 21, 2008 05:25 PM
edrocks3
Nov 1, 2007 03:03 PM
