Sponsored by:
Sponsored by:
Trouble Codes Problems
Old 07-01-2006, 02:45 PM
victors's Avatar
Default Trouble Codes Problems
Hello! I have just bought my Audi A4 2.8 manual 99 and I have the check engine light on. The codes are P1136,1138,0045. The mechanics don't have many ideas and want to start changing parts just to see what's going to happen. If someone can give me some information about the possible problem. I don't want to change parts just to spend some money. Thanks!
Old 07-01-2006, 03:04 PM
david9999's Avatar
Default RE: Trouble Codes Problems
First find a mechanicwho specializes in VW or Audi.
P1136
17544
Bank 1, mixture adaptation (add.)
System too lean 1)
- Road test vehicle (fuel in oil).
- Check fuel system pressure
P1138
17546
Bank 2, mixture adaptation (add.)
System too lean 1)
- Check oxygen sensor behind catalytic converter
I can't find a P0045 code listed. Are you sure that is right.
Old 07-01-2006, 06:55 PM
P1136/8 I would be checking for an air leak,
P0046 is turbo/supercharger related I cant understand you getting that one (unless you have fitted one)?? if not then its a bogus code
Old 07-02-2006, 12:53 AM
victors's Avatar
Thanks for the answers guys. Sorry for the mistake - the third code is P0455(and i have the 3 codes at the same time). Is there someone who has an idea where i can find a good mechanic in Montreal? Thank you one more time!
Old 07-02-2006, 05:28 AM
P0445 = EVAP canister purge valve - short circuit check the wiring
Old 07-02-2006, 09:47 AM
david9999's Avatar
The EVAP cannister purge valve is a black box that sits on top of the airbox. It has wires and hoses going to it. With the engine running put your ear right on it and you should hear it clicking. Also check the hoses and the grey and white check valves coming out of it for cracks and loose connections or sucking sounds that would indicate a vacuum leak. That would give you all three codes.
Old 07-08-2006, 09:32 PM
victors's Avatar
Hello! Thanks guys for the information. It was exactly the EVAP purge valve - there was air coming out. You were right avant80 and david9999. And thanks to you the machanic got it. Now i have to buy and change the EVAP. Thanks one more time for all your answers.
Old 07-08-2006, 11:37 PM
CRAZYHAWK's Avatar
P0455 = gas cap loose.
angelyno55
08-10-2014 09:50 PM
devlzluv
08-01-2010 02:07 PM
2000turbo
11-21-2008 05:25 PM
edrocks3
11-01-2007 03:03 PM
Quick Reply: Trouble Codes Problems
