Trying to take off grille
Old Nov 10, 2007 | 02:56 AM
TheModernAge's Avatar
Default Trying to take off grille
I'm having trouble getting my grille off. I'm planning on painting my stock one just for fun before my RS4 Grille comes. The problem is that I can't seem to get those tabs off. Is there a technique im not getting here? Or do I have to just force the damn thing? Thanks in advance.
Old Nov 10, 2007 | 08:01 AM
ImTheDevil's Avatar
Default RE: Trying to take off grille
You just have to force it gently, if that makes any sense. It helps to start at one end, so there's less pressure on the grille from surrounding tabs. When I removed my rings for paint, I started at one end, levered a tab up gently, then forced the rings out, and worked my way around in a circle. Keep at it and it WILL come off.
Old Nov 10, 2007 | 08:20 AM
turbo kraut's Avatar
Tech Guru
+1 rough but gental......... it will almost be to the point you think you are going to break it, but just before that
those grills are pretty freaking tough
Old Nov 10, 2007 | 11:53 AM
RW42891's Avatar
yeah I had the same problem, you just gotta keep at it. It will eventually come off.
Old Nov 10, 2007 | 02:37 PM
Thanks everybody. I was thinking I WAS going to break it. haha.
Old Nov 10, 2007 | 03:02 PM
chaos92287's Avatar
wait till you try and get the rings out, i thought every one of those little tabs were going to break, and 1 actually did lol
you just gotta start at one side, start pushing tabs in, and work your way to the other side, trick is to have a friend (or if your skilled you can use your elbow) to push the grill out while your doing this, so the tabs dont go back into place. once the top of the grill is sticking out, the bottom will be a piece of cake and should just pop right out
littleA3
Dec 9, 2012 09:03 AM
crazyvegas
Aug 20, 2008 10:03 PM
andrewj654321
Aug 15, 2008 01:06 AM
Deb38
Apr 9, 2007 03:54 AM
zebinheimer
Oct 29, 2006 09:08 PM
