Turbo not boosting
Old Apr 28, 2007 | 09:46 PM
onepoint8tee's Avatar
Default RE: Turbo not boosting
Probably 98%
Old Apr 28, 2007 | 09:49 PM
cincyTT's Avatar
I'm make believe
i guess if you cant you are one! lol
Old Apr 28, 2007 | 10:03 PM
eurokid's Avatar
it's a PICNIC
(problem in chair not in car)
Old Apr 28, 2007 | 11:07 PM
javierh8's Avatar
onepoint8teesorry I could not stay on the forum.
I did not mean to triple post, i am just getting very frustrated with my car. This is my first audi ever and things have not been smooth at all.
My car is not giving a check engine light one and not even a single freaking code. I was advised to change the mass air flow sensor, which I did, and nothing has change.
The only things i have done in my car was upgrade to KO4 and a unitronic chip. I drove amazingly nice for a couple of days, and then one day as I was merging on to the freeway the car hesitate like it was not getting gas and slowly the power started to go away.
Old Apr 29, 2007 | 12:45 AM
Try unplugging the battery for 15-30 mins and see what happens. Its tricky when you dont have fault codes to work with. You saying a 5 bar fpr, or any change to fueling is NOT recomended to use with the k04 unitronics chip? I would find that hard to believe. Not sure how long youve had the chip.. Most places have an unconditional 30 day money back gaurantee. Maybe take advantage of that (if you can)and go with GIAC. You dont hear any odd noises or anything other than its just lost power? Do you have a boost gauge?
Old Apr 29, 2007 | 12:54 AM
cincyTT's Avatar
I'm make believe
10 mins is fine. When you plug it back in, turn your car ON not START. YOu will hear a high pitch whine (tb reseting), when it stops, you can start the car.
Old Apr 29, 2007 | 01:26 AM
javierh8's Avatar
onepoint8tee could there be the possibility of the chip going bad or being deffective? I had the chip for 1 week but it only worked well for 2 or 3 days. I do not have a boost gauge. They did not change the fpr because they said my car already had a 5 bar one.
Old Apr 29, 2007 | 01:31 AM
  #18
The Bishop's Avatar
Check you fuses, could be your ecu fuse.
Old Apr 29, 2007 | 01:34 AM
  #19
javierh8's Avatar
Do you know where is the ECu fuse located?
Warny
May 17, 2012 07:38 PM
nokiamutt
Dec 14, 2007 11:42 AM
Quattro_1.8t
Aug 1, 2007 02:25 AM
Senator
May 13, 2007 12:27 AM
Dj Spiel
Dec 5, 2006 05:57 AM
