turbo question
Old Oct 19, 2007 | 12:32 AM
  #61
chaos92287's Avatar
Default RE: turbo question
ORIGINAL: cincyTT
ORIGINAL: Bogie
anything else i should do chaos?
so people only listen to him now? LOL
Still only think the gt2x is worth getting if it fits your needs. Otherwise, the others are a waste with the no tq and extra lag
muahahahaha. the sig is working already oh and i think the reason arif's numbers were low was cuz they did a 4th gear pull, thats what you do for a 6-speed s4 but 1.8T's should be done in 3rd gear. but yeah the numbers still aren't that impressive.
Old Oct 19, 2007 | 12:33 AM
  #62
cincyTT's Avatar
I'm make believe
power would be higher for 4th than 3rd
Old Oct 19, 2007 | 12:41 AM
  #63
chaos92287's Avatar
yeah your right i was thinkin backwards, there would be more load so higher numbers. 3rd gear is the most accurate tho
Old Oct 19, 2007 | 12:45 AM
  #64
cincyTT's Avatar
I'm make believe
ORIGINAL: chaos92287
yeah your right
Is that my new sig now also?
Old Oct 19, 2007 | 12:50 AM
  #65
jinnyboo's Avatar
i might just get the gt2x.
my friend has a busienss and theres a huge part that he doesn't use so he just turned it into a shop, he did acouple motor swaps in that shop for himself and some friends, i'm sure with help of my friends the labor woulnd't be a huge hassle, so if i go with a gt2x what would i need? and what inch exhaust would be perfect for it.
gt2x.
fmic.
dv.
ecu software.
injectors.
mbc.
test pipe.
w/m turbo coolers.
anything im missing?
Old Oct 19, 2007 | 12:52 AM
  #66
cincyTT's Avatar
I'm make believe
no turbo coolers, w/e that is. Manifold now of in the future would be advised. But thats the jist of it. Go with 2.5" min and 3" max. Both will make great power, but the 3" would be louder.
Old Oct 19, 2007 | 12:57 AM
  #67
Bogie's Avatar
Chaos just chimed in last week on the exhaust, CincyTT. still new here and did't meet you yet so hi.
I was busy bustin on some canadian who called me dumb just before. So will the stock cat have to go with the eliminator?
  #68
jinnyboo's Avatar
would i need a better clutch?
Old Oct 19, 2007 | 12:59 AM
  #69
chaos92287's Avatar
Bogie- no
jinnyboo- if you want to be able to launch it hard than ya. but you can keep your stock clutch for a little while
Old Oct 19, 2007 | 01:01 AM
  #70
jinnyboo's Avatar
mm fancy, i like my friends 6 puck clutch, i forgot that he told me i couldn't speed shift to second, so i grinded his gears. it's a good clutch though, i also heard a 4 puck clutch last long, some of my friends are drifters so yeah... i finally got to drive his mk4 supra it was so damn fast. i nearly wet myself. what clutches do people usally get and are satisfied with it??
