Turbo spools when Idling.???
Old Oct 11, 2007 | 09:22 PM
  #21
cincyTT's Avatar
I'm make believe
Default RE: Turbo spools when Idling.???
ORIGINAL: auditech79
The SAP (secondary air pump) is a worthless piece of crap! The only function of the SAP is to heat up the cat converters faster upon a cold start, thats all it does! If it were up to me, i would rip that piece of dead wieght out of there and toss it in the garbage IMO.
you can, but you wont pass emissions anymore. Somepeople dont have that option
Old Oct 11, 2007 | 09:23 PM
  #22
cincyTT's Avatar
I'm make believe
looks like a bad primary o2 sensor and either bad sai pump or hole in the line. The line is plastic and gets brittle with age
Old Oct 11, 2007 | 09:24 PM
  #23
auditech79's Avatar
ORIGINAL: cincyTT
Doesn't some aftermarket programming eliminate the SAP from the ECM profile? If it doesn't throw a code it will pass as far as i know.
Old Oct 11, 2007 | 09:25 PM
  #24
Noobinator's Avatar
Ok which one is the primary o2 sensor? and where is the sai pump and lines located?
  #25
cincyTT's Avatar
I'm make believe
No, you just remove it and then add a couple of resistors to prevent the cel from going off.
Old Oct 11, 2007 | 09:28 PM
  #26
cincyTT's Avatar
I'm make believe
ORIGINAL: Noobinator
the first one, closer to the turbo. The pump is located under the intake. Start at the line coming off the intake air box and just follow it down to the pump. then follow the line out to the egr/combi valveattached to the engine.
Old Oct 11, 2007 | 09:33 PM
  #27
auditech79's Avatar
Really? I thought i read somewhere that MIKA tuning eliminated the SAP pump from the ECM, even knowing MIKA is as good as a cow pie [:'(]
Old Oct 11, 2007 | 09:38 PM
  #28
Noobinator's Avatar
I think the word "MIKA" should be banned from this forum.
Old Oct 11, 2007 | 09:41 PM
  #29
cincyTT's Avatar
I'm make believe
read this. It has all that useless stuff removed from a jetta 1.8t. <= for audi tech
Old Oct 11, 2007 | 09:53 PM
  #30
auditech79's Avatar
OOOOHHH that last pic is pretty nice! Except for the non protected air filter [:'(]
That still doesn't explain why someone couldn't just elminate those emmision programs from the ECM, but resistors i suppose is easier so what the hell.
