Turbo spools when Idling.???
ORIGINAL: cincyTT
The intake for the 2.0T must suck if the intake did that.
**** the 2ndary air pump, even if its noisy/bad/ Its only useful for a minute and a half on cold starts and then shuts off. It also costs $300+.
You can put a resister between pins on the wiring harness for the sap to fool the ecu if you have it and want to remove it. Some guy on zine was selling block off plates for the headthat eliminate the combi valve if you remove the system.
