Turbo Timer and Alarm/Keyfob Question
So I understand there is no way to make the alarm/keyfob work with a Turbo Timer on the B6? On my previous B5 there was a work around to make it work with the Alarm/Keyfob. Is it completly different for the B6 and the same work around wouldn't work? Curious if anybody has found a way. Thanks in advance!
Link to work around for B5's
ive installed a greddy full auto turbo timer about a month ago, tok me awhile to find straight foward instructions but i did evetually, the key fob will not work with the turbo timer couting down, u habe to lock the doors manually with the key from the drivers side. however key fob will work again once turbo timer has finished counting down and shuts the car off. there is a box that u can buy to bypass the key fob issue, but requires a lot of wiring and i forgot where i found the link.
