Turbo upgrade suggestions/other questions
Old Aug 21, 2006 | 02:58 AM
prf999's Avatar
Default Turbo upgrade suggestions/other questions
I found this turbo kit...
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-VVW 151&Category_Code=VVWTK
Is this a good choice?? if so, I know I need a chip(APR is my choice), injectors(what type), inlet pipe, boost gauge/controller, DV......... is there anything else that I am leaving out??? I also plan on upgrading the pulleys.
Has anyone heard of NEX SS coilovers? Are they all right to use??
Where can I get a good quality RS4 body kit? Is fiberglass, polyurathane, or other material the way to go?
Please help I am in the need for a whole lot more speed!!!!!
Old Aug 21, 2006 | 03:02 AM
AudiCross's Avatar
Default RE: Turbo upgrade suggestions/other questions
Well, that wasnt a link to a turbo kit, but i suggest going to www.awe-tuning.com and select ur car and look at their turbo kit. i trust them
and go to www.goapr.com and check out their kit. Both are reliable and well made.
Old Aug 21, 2006 | 03:55 AM
prf999's Avatar
woops here is the turbohttp://www.horsepowerfreaks.com/pric...art/Eliminator
Old Aug 21, 2006 | 03:59 AM
prf999's Avatar
Here is the coilovers I was talking about......pretty cheap too.
http://www.prostreetonline.com/buy/nex_ss_coilovers/
Old Aug 21, 2006 | 04:07 AM
PandaXpress's Avatar
heres a good APR kit
http://www.purems.com/products/products.php/CA=1451
Old Aug 22, 2006 | 12:10 AM
Emil@RENN=ART's Avatar
we have a solution for you, as well. it's the GTRS kit with unitronic tuning.
this past wednesday i ran 13.5@104 with a bad launch (a simple 1.9 60ft) on pump gas tuning!
with a 1.7 60ft it would have been a 13.1 (judging from the trap speed).. and it was on regular 93oct with street tuning and street boost (20psi).
with race gas and 25psi and a little more timing added to it (5-6 degrees), this kit will run 12's with no problem at all! we should have a video of this very soon.
call tony and tell him you saw it on audiforums and you get 10% off regular price (the GTRS kit is $3207 for the B5 with unitronic tuning)!
Old Aug 22, 2006 | 01:14 AM
blkapra4's Avatar
what else do you need (or is recommended) to install the gtrs kit ?
Old Aug 22, 2006 | 04:27 AM
Besides what comes with our package, you need the following:
- upgraded diverter valve (we recommend Hyperboost HX)
- test pipe or high flow cat
- turboback exhaust
- front mount intercooler (FMIC)
- gauges (boost minimum)
---> a very solid installer!! please don't do it yourself unless you're a mechanic.. it's not recommended!!
recommended to do at the same time:
- clutch upgrade (we recommend the RA4 stg2 or 3 kit.. see our website)
- motor mounts (both the transmission stabilizer bar as well as the snub mount)
- suspension and brake upgrades
* we can supply you with everything above *
Otter11
B7 Models
Mar 18, 2010 01:40 AM
vtraudt
Jan 31, 2010 02:41 PM
supermantfl
Jul 11, 2009 10:35 PM
turb0_clique
Apr 8, 2009 05:52 PM
cred05
Jul 25, 2007 02:05 PM
