turn signal fuse?
Old Apr 15, 2006 | 05:49 PM
jknop2234's Avatar
Default turn signal fuse?
My front right turn signal had been working on and off so i pulled the bulb out and it was burned on one of the sides. When i put in a new bulb it still doesnt work but none of the other lights have problems. Is there a specific fuse for this? Any suggestions?
Old Apr 15, 2006 | 06:39 PM
techbod's Avatar
Default RE: turn signal fuse?
no special fuse mate check to see if its wires are ok and power getting to it, also check to see if it has a ground this could be why it blew with ground shorting out
Old Apr 16, 2006 | 12:04 PM
dankhound's Avatar
Check to make sure the socket itself isnt also burned. You may have to replace the whole socket.
Old Apr 17, 2006 | 04:53 PM
b.roth819's Avatar
ive actually got a similar problem, only with the tail/brake light. i tried replacing the bulb and the brake light works, but the tail light is still out.
pa4ul
Jan 21, 2008 03:20 PM
99 audi
Jan 13, 2008 09:30 PM
DoubleA
Oct 8, 2006 04:53 PM
rcons
Apr 21, 2006 05:31 AM
paliracer
Feb 21, 2005 03:15 PM
