Turn Signal Problem
Hi,
I have a 2000 Audi A4 Quatro. Recently my turn signals, both left and right, stopped working. Initially, it will work few flashes and then it will work sometimes and then it finally stopped working altogether. I checked the fuse, it seems fine, but I still changed it. After the right one worked for few flashes and then stopped working. The hazard signals working fine.
Does anyone know what could be the problem here. A little search tells me that it could be the flasher relay which is under the hazard light, and might be tricky to fix. I am not very DIY person, so I was wondering how much it would be to fix at a repair shop.
Thanks for any help that you could provide.
This is a very easy DIY actually.
https://www.audiforums.com/forum/diy...doright-17621/
BUT if you want to bring it to a dealer, plan on $100-$200. Basically 1 hour labor time (minimum billable amount) and ~$90 for the flasher.
