I'm make believe
nothing like low numbers and 600rmps extra lag over a true gt28rs
What tuning are you running because your power goes to **** at 5k? I guess it could also be a poor boost control also. your entire power is just a peak and drop over a few hundred rpms.
I think the lag is caused by what was dialed in on the EBC.. not sure why the power band is like 200rpms
totally blows
totally blows
Quote:
ORIGINAL: sean1.8t
revo right? what are you set at? MAF or no? what's your MBC/EBC set to? oh and what octane?
EBC, yes its REVO, no MAF... 101 octaneORIGINAL: sean1.8t
Quote:
ORIGINAL: cincyTT
Have any timing logs and boost requested vs actual? Those should help some
logs coming shortlyORIGINAL: cincyTT
I'm make believe
Quote:
ORIGINAL: Redgoatâ„¢
logs coming shortly
pump those number are so so, on 100+ octane, there is deffinatly a problem ORIGINAL: Redgoatâ„¢
logs coming shortly
cool
I'm make believe
The first chart has the timing bouncing everywhere. Also in the last two its way to low in the 5.5+rpm range. your at 5-8* advanced where most are 15-24* advanced to redline.
As for boost, you are pretty far below requested till almost 4k and then you are spot on for about as long as your power is strong on the dynos and then you are a good amount above it from about 5300rpm's on
That first chart is pretty bad altogether where the next to are so so. Have you tried the MAF yet? Sorry Sean, just asking.
