umm this doesnt look good (dyno results)
Old Aug 3, 2007 | 01:04 AM
sean1.8t's Avatar
Default RE: umm this doesnt look good (dyno results)
hey, no worries Cincy. my logs are golden. unlike Karl's... this was all a recent thing when you had your turbo fixed isn't it Karl?
Old Aug 3, 2007 | 01:27 AM
Karl's Avatar
The car sat for about 3 weeks.. no MAF as of yet.. going to throw that in and see if i can get some better logs.
Old Aug 3, 2007 | 01:49 AM
Karl's Avatar
ORIGINAL: cincyTT
The first chart has the timing bouncing everywhere. Also in the last two its way to low in the 5.5+rpm range. your at 5-8* advanced where most are 15-24* advanced to redline.
As for boost, you are pretty far below requested till almost 4k and then you are spot on for about as long as your power is strong on the dynos and then you are a good amount above it from about 5300rpm's on
That first chart is pretty bad altogether where the next to are so so. Have you tried the MAF yet? Sorry Sean, just asking.
So any suggestions on what could be the problem??
Old Aug 3, 2007 | 12:45 PM
cincyTT's Avatar
I'm make believe
Best guesses right now are: boost control, bad gas, or needs the maf.
Was the 100octane leaded by chance?
Old Aug 3, 2007 | 03:30 PM
Karl's Avatar
gas was unleaded.. will throw the maf in and do some logging
Old Aug 3, 2007 | 07:32 PM
david9999's Avatar
Looks bad. I would love to have those numbers.
Old Aug 4, 2007 | 03:41 AM
Karl's Avatar
These logs look any better??
http://spreadsheets.google.com/pub?k...JIxTDuzHPwqRTQ
http://spreadsheets.google.com/pub?k...JIztKn8EkdSaRA
Old Aug 4, 2007 | 11:37 AM
  #18
Belligerenceā„¢'s Avatar
I'm pretty new to the logs thing, but it looks to me like your timing is still not being advanced anywhere near as much as it should be between about 3.5K and redline. bad knock sensor maybe?
Old Aug 4, 2007 | 02:06 PM
  #19
cincyTT's Avatar
I'm make believe
Your timing looks ok until about 4500rpms and then it never comes back up. Here is a log it should look more like, its a uni 630 file with a 30r @ 19psi.
So did it feel any better with the maf, it looked a little smoother but still with a timing issue?
Old Aug 4, 2007 | 03:42 PM
  #20
Karl's Avatar
It felt better without the MAF, but the numbers show that its running better with the MAF.. The timing issue might be the timing map that im running
