Is upgrade anti-roll bar a must if I lower the ride?
Old Oct 19, 2006 | 04:57 AM
kchao2000's Avatar
Default Is upgrade anti-roll bar a must if I lower the ride?
Guys,
My ride is 04 3.0Q base model with 17" wheels. I am about to order Koni FSD + Eibach Pro Kit from Tirerack. Since Eibach Pro springs will lower the ride about 1.2", should I upgrade the stock non-sport anti-roll bar? If it is OK to use the stock non-sport ones, I would rather save the $$$ now. If it is a must, can you recommand any good and easy install anti-roll bars?
Thanks for your help.
Old Oct 19, 2006 | 05:20 AM
PandaXpress's Avatar
Default RE: Is upgrade anti-roll bar a must if I lower the ride?
its not a must but it will improve, u can just upgrade the rear sway
ORIGINAL: kchao2000
Guys,
Old Oct 19, 2006 | 06:17 AM
BadLuckAudi's Avatar
not a must but it will be nicer
Old Oct 19, 2006 | 08:16 PM
kchao2000's Avatar
Thanks for the input. One more question, if I decided to put on shocks and springs right now and sway bars later, do I need to do alighment twice? I know shocks and springs required an alignment what about sways?
Thanks.
Old Oct 19, 2006 | 08:23 PM
mjvss21's Avatar
no sway bar does not require an alignment
Old Oct 20, 2006 | 12:18 AM
MC Hammered's Avatar
The answer is 'No' but if you do upgrade get a set of H-Sport swaybars.
It will be the most noticable mod you will do to your car.
With Quattro your car will turn as if it was on rails.
Old Oct 20, 2006 | 03:41 AM
kchao2000's Avatar
H-Sport sway bars is the one I am going to get either now or in the future(most likely now). Does it required any special instructions to install it? Because if I cannot find any good shop around my area, I might just go to local tire shop or garage to get it done.
ORIGINAL: MC Hammered
Old Oct 20, 2006 | 11:37 AM
bajamoon's Avatar
you can do the sway bars yourself, i put mine on and it took about an hour for front and rear, just a few bolts and make sure you put it on the right direction because you can put it on backwards, i was at hotchkis and they did and it could do serious damage.
Old Oct 20, 2006 | 05:37 PM
captnmorgan's Avatar
ORIGINAL: bajamoon
how do u like the front sway bars? i understand they cause alot more understeer? hows that working out for you?
Old Oct 20, 2006 | 08:27 PM
bajamoon's Avatar
i don't have the h-sports, i have the h&r's, when the car was lowered it handled better than i could imagine but then i got into tie rod issues and the suspension got really loose after about 6 months, they are still on with the car being stock and it still handles great.
muscletat
Jun 23, 2013 07:49 AM
ianc
Aug 20, 2009 03:47 AM
harryc
Sep 24, 2006 07:29 PM
molon labe
May 10, 2006 09:49 PM
Skuy4
Jul 25, 2004 07:44 PM
