URGENT!!! HELP!! engine problem
Old Dec 20, 2005 | 10:57 AM
Fieldy's Avatar
Default URGENT!!! HELP!! engine problem
Hey guys,
I have a 2000 1.8t. This morning (about 20 degrees out), I started the engine, and the whole car is rumbling and making an unhealthy engine noise. After about 20 seconds the check engine light turns on and starts flashing. I repeated the whole process once to make sure, and the same thing happened. Car has 130K on it.
Does it sound like a timing belt problem or what>!?!?!
Thanks
Old Dec 20, 2005 | 11:36 AM
insuite's Avatar
Default RE: URGENT!!! HELP!! engine problem
Codes?
Old Dec 20, 2005 | 12:06 PM
Fieldy's Avatar
no codes...yet, but it seems like the symptoms of coil pack problems from what I am researching.
Old Dec 20, 2005 | 01:01 PM
Slowb5's Avatar
Same thing happend to me a while back, all it was was a dead cylinder...the sparkplug wasnt firing...it ended up being that little dealie on top of the air box. swap the coil packs...try again...and if that doesnt help any, check the sparkplugs...and if you FINALLY get a code, check that little power control module.
Old Dec 20, 2005 | 01:06 PM
clconversion's Avatar
2000's do not have the power control module get the car vag'd see which cylinder is misfiring switch coil packs with another one and if the problem goes to the other cylinder you have a bad coil pack that sounds like your problem
Old Dec 20, 2005 | 02:50 PM
Fieldy's Avatar
alright thanks a lot guys, im getting it towed in the next 30 min.
Old Dec 20, 2005 | 05:17 PM
Fieldy's Avatar
turned out to be shitty spark plugs that caused my 2nd cylinder to misfire.
moral of the story: dont be cheap when buying spark plugs.
Old Dec 20, 2005 | 09:03 PM
John_E's Avatar
ORIGINAL: Fieldy
I am definitely not cheap with spark plugs. I spent $10 EACH on OEM NGKs. I am used to spending less than that for a full SET.
mikas
May 16, 2013 09:00 PM
podge99
Jul 21, 2011 08:32 PM
samleong
Feb 2, 2009 08:01 AM
TurboQuattro
Aug 11, 2007 10:00 AM
meg27
Jan 31, 2006 08:02 AM
