Vacuum Leak!!! GRRRR
Old Mar 27, 2007 | 12:39 AM
Audi_Skydiver's Avatar
Default Vacuum Leak!!! GRRRR
Ok, So I know I have a vacuum leak because when I am idleing I am at 11hg. I have read that you need to be somewhere around 20Hg correct? Anyways, I have tried searching (I typed in "finding vacuum leaks"; "vacuum leaks") And did not find what I was looking for so if this is a repost please don't flame just give me a link or shut your...fingers. IDK what that was sorry. LOL
Anyways my question is, how do i go about finding a vacuum leak? What do you guys normally do? Thanks
Josh
Old Mar 27, 2007 | 12:56 AM
Boostfed13's Avatar
Default RE: Vacuum Leak!!! GRRRR
Carb Cleaner why because it burns like fuel so when you spray it on your vacume lines when you find your leak your idle will raise because more fuel is being sucked into the maifold.
Old Mar 27, 2007 | 01:01 AM
qUaTtRoA4's Avatar
alot of the time they are both visible and audible, pop your hood and start pulling your vac lines....gl!
Old Mar 27, 2007 | 06:03 AM
ok, thanks guys!
Now I just need to actually go out and do it!!!
Josh
Old Mar 27, 2007 | 08:25 AM
x1rider's Avatar
propane can also work (same principle as carb cleaner)
Old Mar 27, 2007 | 10:59 AM
alias747's Avatar
Well Josh after installing my boost guage I def don't have a vac leak, my vac at idle is anywhere from 19-25. However I def could have a boost leak. I need to completely finish up my isntall today and then take a vid of my gauge and see what people think, if I have one or not.
Old Mar 27, 2007 | 04:02 PM
how did the install go? Sorry I didn't get you pics
Josh
Old Mar 27, 2007 | 05:23 PM
Babz's Avatar
Start from the boost gauge and go towards the engine. After i installed my boost gauge i had -15 vacuum and after searching realised it was my vacuum line going to the gaugethat was pinched.
Old Mar 27, 2007 | 05:26 PM
OK, I will do that.
Thanks
Josh
fuzz_duster
May 2, 2017 05:25 AM
tmac85
May 27, 2013 09:10 PM
dbacon89
Aug 15, 2010 10:34 PM
2000turbo
Jul 26, 2010 08:17 AM
x1n54n3x
May 8, 2009 04:40 PM
