VAG Codes Please help to decipher`
Old Nov 12, 2007 | 11:45 AM
ind_dsnr's Avatar
Default VAG Codes Please help to decipher`
Hello,
My "check engine" light came on this weekend and i pulled the following codes. Also, the EPS light comes on intermeittently. What could be the cause of that? I have a 2003 A4 3.0 with Tiptronic.
Thanks
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 559 E
Component: 3.0L V6/5V G 0004
Coding: 0016751
Shop #: WSC 00000
2 Faults Found:
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 002 - Lower Limit Exceeded
16485 - Shareware Version. To Decode all DTCs
P0101 - 008 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 0912
Coding: 0001002
Shop #: WSC 63251
2 Faults Found:
18265 - Load Signal: Error Message from ECU
P1857 - 003 - Mechanical Failure - Intermittent
18258 - Shareware Version. To Decode all DTCs
P1850 - 003 - Please Register/Activate - Intermittent
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04497
Shop #: WSC 63274
2 Faults Found:
P1857 - 35-10 - - - Intermittent
P1850 - 35-10 - Please Register/Activate - Intermittent
ClintLugert
Oct 21, 2012 11:35 AM
roke2468
Oct 31, 2011 10:18 AM
dbansal
Jul 14, 2008 01:52 PM
5SpeedJazz
Oct 8, 2005 10:46 AM
