vag com - 2002 A4
Old May 2, 2006 | 05:45 PM
Audi42005's Avatar
Member
Default vag com - 2002 A4
I purchased an Third party Interface that claims to be Dual K (KKL) and to be compatible with version 409.1. It is a USB interface and i am pretty sure that i have installed it on my computer correctly but when i plug it into my car it won't communicate and says interface not found, but it says that the interface is found when not hooked up to my car. It also does not detect that it is plugged into the USB, it is detecting it in COM4. anyone have any experience with this and give me some tips..... thanks
Old May 2, 2006 | 05:49 PM
onepoint8tee's Avatar
Default RE: vag com - 2002 A4
go to control pannel.. click on system, go to Hardware, go into device manager, right click the usb interface/serial port and go into the properties and switch from com4 to com2, or whatever is available, then go into vag com setup and select com2 (or whatever one you chose that wasnt com4)... thats what i had to do.
Old May 2, 2006 | 05:57 PM
Audi42005's Avatar
Member
thanks, i am not plugged into my car right now but it is saying Port status: OK , Interface: Not found
Old May 2, 2006 | 06:01 PM
yeah just doooo it.
Old May 2, 2006 | 06:02 PM
Audi42005's Avatar
Member
ok, i just don't understand why it isn't detecting that its plugged into the USB. but thanks, i'll have to try it then.
Old May 2, 2006 | 06:13 PM
are the drivers for it installed???
Old May 3, 2006 | 02:44 AM
Audi42005's Avatar
Member
yes
Old May 3, 2006 | 03:18 AM
Jovian's Avatar
What system is this? and most likely the com port will have to be set like onepoint8tee is saying. I know with the ODBII reader I have depending on which USB port I use I have to put a differnt com port in Example 8 or 10.
The software I have is Digimoto and the cable is a mOByDic.
Go to Device Manager like Onepoint8tee said and go to the USB section and find it. It will list the com port there.
Old May 3, 2006 | 03:33 AM
Audi42005's Avatar
Member
Its Vag Com....i haven't tried it on my car since i changed the com port... but i'll play around with that
johnpalley
Jun 30, 2011 11:08 PM
sports265
Jun 10, 2009 10:37 PM
02LSBM3
Jan 20, 2007 03:32 PM
aaks38
Jan 15, 2007 02:10 AM
Vegabond
Sep 27, 2005 05:26 PM
