Sponsored by:
Sponsored by:
Valve Problem?
Old 08-15-2006, 03:34 AM
primo537's Avatar
Default Valve Problem?
hey. I have a 98 a4 1.8T 63,000miles
recently ive been getting a constant tapping sound comming from the engine when im idleing. I scanned with vag and came up with
17965 - Charge Pressure Control : Positive Deviation
P1557 - 35-10 - Intermittent
any ideas?
thanks
Old 08-15-2006, 03:38 AM
primo537's Avatar
Default RE: Valve Problem?
Btw my mods are a giac chip and a 710n DV.
Old 08-15-2006, 04:31 AM
onepoint8tee's Avatar
I dont think that code has anything to do with the tapping. The tapping could be your cam chain. The code means you are underboosting, or that the actual boost is less than what the ecu is requesting. Check for boost leaks.
Old 08-15-2006, 05:07 AM
zat0rsk1's Avatar
i have the same problem primo. It doesnt effect my performance though. From searching around Ive found that its valve timing , or it could be. The tapping gets louder or goes faster as the rpms go up. Does yours?
Old 08-15-2006, 05:47 AM
primo537's Avatar
actualy my tapping goes away as the rpm go up
DimitarStaykov
05-25-2013 07:33 PM
stetec
10-12-2009 11:04 AM
littlun1
04-24-2009 07:42 PM
tatensty
03-13-2008 04:46 PM
aznek
03-26-2007 12:17 PM
Quick Reply: Valve Problem?
