Vibration in shifter
Old Nov 2, 2005 | 09:59 PM
cdf619's Avatar
Default Vibration in shifter
Was wondering if anyone else has encountered vibration in the shifter while in 2nd gear. This is nothing intense but a little shake. Only really notice in 2nd.
Old Nov 2, 2005 | 10:04 PM
headshok2002's Avatar
Default RE: Vibration in shifter
I think that is pretty normal. Just in the shifter? Not the whole car shaking? That would be pretty normal I think.
Audi says not to hold on to the shifter, unless you are shifting. So let go and you wont notice!
Old Nov 2, 2005 | 10:06 PM
cdf619's Avatar
Figured that it was nothing just thougt I would ask.
Old Nov 2, 2005 | 10:12 PM
Yeah, I live a life full of fear as well... I can barely afford my car, so it's little quirks can be terrifying -- as we all know how much money they can be to fix.
Old Nov 3, 2005 | 12:11 AM
sandman's Avatar
yea mine does this too.
Old Nov 4, 2005 | 09:16 PM
6thgear's Avatar
Mine jumps forward then back when in 6th when you are barely on the gas. Anyone else have this? It seems like its reacting to the differential changes. When i say jump i should say changes position, but it always stays firmly in gear.
Old Nov 4, 2005 | 09:32 PM
gsxr150's Avatar
My 02' does it in second gear mostly... No big deal though...
Old Nov 10, 2005 | 06:10 AM
ackjazz's Avatar
Mine did that - I know the shifter connections to the transmission can be adjusted. There are two places that can be adjusted, but you have to know what you are adjusting. The reason for the vibration (and there is nothing wrong) is the fly wheel produces mild vibrations at certain RPM's, therefore conveying sympathetic vibration into the shifter.
If you can make it happen at the same RPM in third as in second, you'll know that's what it is.
Pretty normal though.
By the way, if you ever change the clutch and replace the flywheel with a lighter one (11.5 lbs vs. 25 lbs) you'll definitely feel vibration as the flywheel is getting up to speed (around 2500 RPM).
ORIGINAL: cdf619
jibberjive
Feb 24, 2009 12:57 AM
jibberjive
Jan 9, 2009 09:16 AM
bobbyreds1
Jun 2, 2007 08:27 AM
jlinaschke
Feb 9, 2007 10:17 PM
apg96
Nov 8, 2005 10:37 PM
