Volumetric Efficiency
Old Mar 21, 2005 | 10:46 PM
Shaunp05's Avatar
Default Volumetric Efficiency
If my engine has a Volumetric efficiency rate of 85%
this is the most A/F mixture it can pack into its Camber
in its 4 stroke cycle >?
So why is it that if you put on a turbo or Supercharger you can
gain more HP and torque with the same VE rate of 85% ?
You not putting more air in the camber you just precompress it befor
the Intake valve ?
So why does it make more power with same VE rate???
Old Mar 21, 2005 | 11:37 PM
Doose's Avatar
Default RE: Volumetric Efficiency
Because more air allows the engine to use more fuel. More air + more fuel in the same size cylnder = larger explosion = more power
Old Mar 22, 2005 | 12:23 AM
Jestnomen's Avatar
6th Gear
ORIGINAL: Shaunp05
You not putting more air in the camber you just precompress it befor the Intake valve ?
Yes there is more air. Higher compressed air retains the same volume of space, but has more molecules of O2.
Old Mar 22, 2005 | 12:53 AM
Shaunp05's Avatar
So if you had the same amount of air in the mixture and you drop the air temp
and make it more dense would you not have the same effect ?
The new Ford F150 uses the same method and runs the intake charge through
ther Evap to cool the air charge, so it still has the Base 14.7:1 A/F ratio but more
dense with huge power gains ???
Old Mar 22, 2005 | 01:01 AM
Jestnomen's Avatar
6th Gear
I don't know what you are asking.
By cooling the air it becomes more dense. Denser air contains more particles of o2. This means the injectors can spray more fuel to maintain the a/f ratio. By having more fuel and air in the cylinder you are able to create more power per power cycle.
Doose's Avatar
Here's a pretty good explanation.
Turbo / Super Charger
IslandHydro
Oct 29, 2012 12:35 PM
vtraudt
Oct 12, 2010 09:18 PM
jude14601
May 1, 2008 07:14 PM
dynamicav1971
Mar 9, 2008 03:03 PM
bogusz
Jul 12, 2007 11:06 PM
