warming up
Old Dec 1, 2004 | 10:06 PM
DDonG's Avatar
Default warming up
just out of curiosity...how long does it take for you guys to warm up your cars? the people with 1.8Ts that is
Old Dec 1, 2004 | 10:12 PM
Jestnomen's Avatar
6th Gear
Default RE: warming up
You are not suppose to warm up the car. Just start it up, and 30 seconds or so later pull away. Keep the RPM's under 3k untill the engine is warm.
Old Dec 1, 2004 | 10:28 PM
njcoach's Avatar
biggest myth is to sit there for 3 to 4 minutes... that just kills your car
Old Dec 1, 2004 | 10:34 PM
Jestnomen's Avatar
6th Gear
Pretty sure it says right in the manual that warming up the car wears on the engine.
Old Dec 1, 2004 | 10:36 PM
PaulA4's Avatar
Driving with low revs as Jestnomen says is the best way, if you sit there from cold and idle to warm up, the lack of oil pressure will let the top parts of the engine run dry for a while. Driving off straight away taking it easy will build pressure.
Old Dec 1, 2004 | 11:35 PM
brrman's Avatar
agreed - do not sit and warm you rcar up. Make sure you are moving to warm the car, with low revs until the temp gauge moves up at least one notch.
Old Dec 1, 2004 | 11:51 PM
DDonG's Avatar
oh really...damn...i always thought sitting there and letting it warm up was good for the car...thanks for clearing that up
Old Dec 2, 2004 | 06:28 AM
PandaXpress's Avatar
OMG i been hurting her when i thought i been helpin her, damn it. NOOOOOOO
well at least on the bright side im gonna save alot of time now
Old Dec 2, 2004 | 09:29 AM
david9999's Avatar
Unless any of you drive in Saskatchewan in the winter, when the temperature is 30 or 40 below, there is no need to warm up the engine. It just wastes fuel and time. Of course if you live in the northern US, make sure you arent running 15W50 oil either.
bvnguyen516
Apr 3, 2008 12:34 AM
audiprotein
Feb 20, 2007 11:23 PM
SHARKBITEATTACK
Sep 1, 2006 03:02 AM
CaliA4
Nov 2, 2005 02:37 AM
