Warning FYI
Old Jan 6, 2008 | 03:08 PM
eurwaudi1.8's Avatar
Default Warning FYI
I came out to my car friday morning and started it went back in the house to let it warm up (9 deg) when I came out there was oil all over the ground. Not just a little oil about 4 quarts, and the valves were clattering of course. I shut the engine down imediately and opened the hoodit was not obvious as to where the leak came from so I few quarts in and started it. Oil sprayed out from above the oil cooler, I droped the oil cooler and found the o-ring that seals the oil cooler to the bracket to be split. I went to remove the o-ring and it literaly cracked and crumbled into pieces. Do yourself a favor r and r this o-ring if you have over 100,000 on your car, it only takes about a half hour. I am glad it happened that day because the day before I was traveling 100 miles at about 80 mph the whole way, think about what could have happend if i dumped my oil then!
Old Jan 6, 2008 | 06:08 PM
CRAZYHAWK's Avatar
Default RE: Warning FYI
I run Mobil 1 10W-40 High Mileage Oil. I think theyput seal conditioner
in it.
Old Jan 6, 2008 | 11:38 PM
Steel02001's Avatar
My car just hit 100,000 and the oil cooler, lines and rings were just replaced as they needed it. I dont know how common of an issue this is (I am definitely new around here), but sounds like something you should check out with you do the 90,000 miles tune.
L4AH4N
May 23, 2011 07:25 PM
L4AH4N
Nov 8, 2010 07:29 AM
Harlemz4_Os
Jul 10, 2007 07:42 AM
nemo2182
Aug 24, 2006 09:31 AM
jetskidia
Apr 15, 2005 12:57 PM
