wastegate actuator
Old Sep 10, 2005 | 04:34 AM
petermcA4's Avatar
Default wastegate actuator
I've done a search on this, but couldn't find too much info;
Is it a common problem on the 1.8T for the wastegate actuator to fail?
Could this be the reason i'm loosing boost?
I've checked the vacum hoses and all the rest, but found nothing wrong there.
Any help would be great. Thanx
-Pete
Old Sep 10, 2005 | 12:43 PM
david9999's Avatar
Default RE: wastegate actuator
It is not common for the wastegate actuator to fail.
What makes you think you are loosing boost? Have you checked the boost pressures?
The most commont problems are boost leak due to a loose or broken line between the turbo and the throttle body or a bad diverter valve.
james007d
Aug 26, 2011 10:16 PM
james007d
Aug 20, 2011 09:41 PM
vtraudt
Feb 18, 2010 10:23 PM
Naninani
Jun 4, 2008 07:56 AM
98A4TQ
Mar 12, 2007 08:30 PM
