water leak anyone? 1.8T 1999
Old Dec 23, 2005 | 04:14 AM
reneriarik's Avatar
Default water leak anyone? 1.8T 1999
anybody have a problem with a water leak in the passenger side? it soaks my carpet up when it rains and when I wash it, I pulled the carpet down and it comes from the very right corner, I put water by the fender/hood close to the windshield and it goes in but its not my windshield and the drain hole by the battery is not plugged.
Old Dec 23, 2005 | 04:42 AM
BLAZEDUPBEE's Avatar
Default RE: water leak anyone? 1.8T 1999
you might wanna check the seal around the cabin air filter, and check your door seals. i have the same problem on my drivers side and i was told it might be the seal where the computer is
Old Dec 23, 2005 | 02:14 PM
Kellya4's Avatar
Have you had the windsheild replaced? I had a simmilar problem w/ my wifes old chunk of crap, the windsheild was replaced, but it leaked.
Old Dec 24, 2005 | 01:53 PM
dankhound's Avatar
One of your sunroof drains is probably leaking.
Old Jan 31, 2006 | 06:28 PM
jcwdriver's Avatar
I have the same problem. I've owned this car all of 4 days and I came out to find an inch of water in my drivers footwell, and drivers side rear foot well.[:@]
I don't know A4's very well, so any help is appreciated.
Old Jun 24, 2006 | 10:10 AM
ddd's Avatar
ddd
It is also my problem now. A few weeks back I thought the little flood I passed cause all the water to go into my car. Bad enough to go to my auto transmission control unit and mess it up. By now I am sure I have now passed any flood, it just rained alot and now the carpet soaked in the rear passenger side again[&o]
Old Jun 24, 2006 | 10:17 AM
david9999's Avatar
Probably the drain channels from the sunroof
Old Jun 24, 2006 | 10:31 AM
ddd's Avatar
ddd
ORIGINAL: david9999
I don't have a sunroof... I did open the other links to my leak search, I found out that there is a drain that is under the battery. I will check it tom, hope I find the leak before it messes up my tip transmission again.....
Old Jun 25, 2006 | 12:15 AM
afruss2007's Avatar
I've got the same problem. I've been in the market for an Air Compressor to try and clear the Sunroof drain. Haven't gotten a chance to try it all out yet, but it would be nice to know if that's all you have to do is just shoot some compressed air down there to clear out the drain. I would think that should do it.
Old Jun 25, 2006 | 05:41 AM
ddd's Avatar
ddd
Found this link, its actually of a passat but the engine is quite similar to the a4 and I guess we also have a few of the same problems.
Hope this helps anyone with similar problems, I will try them out tom.........
http://www.weirdlittlebiscuit.com/passat/leak/
