we need a s/c 2.8!
Old Sep 6, 2007 | 05:50 PM
  #21
LowA4's Avatar
Default RE: we need a s/c 2.8!
I just picked up an s/c for a good deal but have been debating if I should put it on a 113,000 mile engine. I believe I have 9 and 12lb pullies. If I do decide it's going on it'll be in March when I get 1 of my other cars back on the road so I can afford the down time for this one. I'm wondering what 1/4 mile times would be on the car afterwards.
Old Sep 6, 2007 | 05:54 PM
  #22
onepoint8tee's Avatar
ORIGINAL: LowA4
WTF PUT IT ON!
Old Sep 6, 2007 | 05:58 PM
  #23
ImTheDevil's Avatar
Chances are, if you have an engine in good shape you'll have no problems. I'd maybe do a compression and leak-down test on it, and if that's good and your maintenance has been done appropriately, the engine should be plenty strong to handle it. If it were me, I'd run the 9 lb pulley first and make sure everything is good. If so, step it up. What might be a good investment would be an EGT gauge plumbed into your exhaust stream - this will give you a good idea of how well your injectors are handling the increased load. If they're faltering (whether from being worn out or weak or whatever) it'll lead to elevated exhaust gas temps. EGT is a very good idea on a boosted engine, and it will give you far better info than some crappy, non-wideband air/fuel meter.
Old Sep 6, 2007 | 06:07 PM
  #24
LowA4's Avatar
It came witheverything, charger, pullies, ecu, injectors, etc. all new never installed. The engine runs great, no smoke or anything so I most likely will put it on. Compression check is first on the list. My Formula will be running low/mid 11's and I know it won't keep up with that but I want it to do fairly well at the track if I decide to run it on 1 of my trips.
Old Sep 6, 2007 | 06:13 PM
  #25
ImTheDevil's Avatar
Sounds like you're in a prime position to put it on there. I'd still do a leak-down test as well - a good euro shop can probably do one for you for about an hour's labor. It'd be smart to do, just for the added peace of mind. I don't know for sure, but you may want to do a little research into the torque-handling capabilities of the OEM clutch - it may decide to bow out shortly (and possibly dramatically) after you throw another 100+ ft-lbs of torque at it, and if that's the case, better budget for an upgraded clutch as well.
Old Sep 6, 2007 | 06:18 PM
  #26
LowA4's Avatar
Oh, yeah, already thought of that. I might go with a Southbend, stage3 I believe. The 1st time I tried to take off across traffic really quick, I tried taking off at 3500 rpm and let the clutch out and it slipped like hell. haven't/won't do that again till I get a good clutch.
Old Sep 7, 2007 | 12:50 AM
  #27
sdsteez's Avatar
i couldve sworn someone found a nice s/c for a 12v...? if so, my buddy has the cash right now to drop on it if anyone can find the one im talking about
Old Sep 7, 2007 | 02:34 PM
  #28
The Motodyne s/c for the 12 v is/was a pos. People had lots of problems with it and there is/was no customer support, etc. Its still advertised on a website, but if you try to ask them quesitons about it youll get told to "**** off" from what Ive heard.
Old Sep 7, 2007 | 03:29 PM
  #29
klum00's Avatar
yeah do your research, there is NO SUPERCHARGER for the 12v's period. Well one that words at least.
