Weird Gurgul Noise????
Old Mar 2, 2007 | 06:00 PM
Audi_Skydiver's Avatar
Default Weird Gurgul Noise????
Hey,
Something that is weird with my A4 when I start it is that every so often (Mostly on cold mornings) when I start my car I can hear a really weird gurgal noise coming from the engine compartment. Any ideas? It stops after the engine warms up though. Doesn't seem to affect anything either. Just wondering. Oh and also, I have a 1999.5 Audi 1.8T and I was wondering if you could put an ECU from a 2001 Audi A4 1.8T in my car? Becuase that would give you an extra 20hp right? Since the 2001 and on have 170hp while the earlier models have 150? Just wondering.
Josh
Old Mar 2, 2007 | 06:30 PM
onepoint8tee's Avatar
Default RE: Weird Gurgul Noise????
No you cant switch ECU's. You are drive by cable, 00+ is drive by wire. Dont know about the gurgling noise... Check your fluid levels.
Old Mar 2, 2007 | 06:35 PM
techbod's Avatar
air in the heater matrix bleed the system
Old Mar 2, 2007 | 07:16 PM
wildlife9000's Avatar
i got the same noise every morning i start up. it only lasts 2-3 sec's, not a big deal. avant80@2.6 you said its air in the heater matrix? how do you bleed that?
Old Mar 2, 2007 | 07:32 PM
techbod's Avatar
put the heat on fill with the expansion cap off ( filler cap ) then let the coolant fan cut in and dont worry about the coolant overflowing because that's normal just refill when completed
Old Mar 2, 2007 | 08:10 PM
BadLuckAudi's Avatar
good call old man good call !!!!
ORIGINAL: avant80@2.6
Old Mar 2, 2007 | 08:14 PM
techbod's Avatar
well thankyougish nearly old fartish age will get you one day
Old Mar 2, 2007 | 08:21 PM
lol oh i know it, but i got a long way till then hopefully I will be as wise as you when i get there
audia4man
Dec 27, 2012 08:14 AM
pyth47
Mar 26, 2009 11:40 AM
brodieone
Nov 9, 2007 04:21 PM
NuYorka103185
Mar 15, 2007 10:37 PM
cas4067
Aug 19, 2006 12:28 PM
