Does it do it when you go over bumps? It could be a TieRodEnd or your CV joint. Look at it and see if the boot is cracked or loose or something.
Josh
Edit: Or it could be a wheel bearing but that makes more of a grinding noise doesn't it? Not completely sure on that one.
Josh
Hi im having prblems with my factory Bose factory radio on my audi a4 wagon 2002. I just can hear sound on thepasenger side fron and back but in the driver side in not soun at all can somebody give my some answer please? thanks.
check the balance on the radio. u can make the sounds left or right. not sure wut the buttons on the b6 is but my b5 have these ***** and it says balance on one of them
That would do it! Get it replaced and then fill it with grease. Glad it was something simple!
Josh
Josh
