what is currently the best turbo upgrade for the a4 B5 under $2000
Old Oct 10, 2006 | 11:04 PM
avp689's Avatar
Default what is currently the best turbo upgrade for the a4 B5 under $2000
just started saving up and i want a car faster than my friends modded vr6 jetta
Old Oct 10, 2006 | 11:25 PM
david9999's Avatar
Default RE: what is currently the best turbo upgrade for the a4 B5 under $2000
K04 and programming and 5 bar fuel regulator will run you about 1300 dollars. That leaves 600 for a high flow exhaust.
Install is extra.
Old Oct 10, 2006 | 11:50 PM
chuckievi's Avatar
I think Tomritt can hook you up with a cummins diesel that will SMOKE your friends car....
Old Oct 11, 2006 | 02:14 AM
Johnnyd3689282's Avatar
i would go witht he K04, Fuel pressure DV and exhaust
Old Oct 11, 2006 | 02:46 AM
A4speed's Avatar
Depends on how big you wanna go, are you going for huge power?
Old Oct 11, 2006 | 06:38 AM
chaos92287's Avatar
for under $2k the only option is the ko4. its a direct replacement so you dont need to change anything else in the engine, just programming.
Old Oct 11, 2006 | 04:23 PM
JohnnyBravoA4's Avatar
if its an AEB i would try and save up a little more money and go with the pc-16 file with the ko4, i have been having mad problems with the k04 giac program
Old Oct 11, 2006 | 04:59 PM
clconversion's Avatar
definetly for $2000 you are only going to get a K04 and programming unless you can find a used BT upgrade but what would help us a lot is by telling us what is done to the Jetta ?
Old Oct 11, 2006 | 05:02 PM
smokeU's Avatar
33 turbonators
Old Oct 11, 2006 | 08:50 PM
b52000a4's Avatar
JohnnyBravoA4 Date 10/11/2006 1:23:02 PM
Why would you say "if he had an aeb?"
KeshA4
Nov 20, 2012 11:21 AM
sollyd25
Mar 19, 2011 09:27 AM
5Speedwtneed
Nov 2, 2010 10:44 AM
jimUK_2
Jan 18, 2007 05:55 PM
LaXer6188
Aug 15, 2005 11:39 PM
