What does this code mean? 18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
Old Dec 23, 2007 | 05:48 PM
traian2003's Avatar
Default What does this code mean? 18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
I had this code for quitea bit of time. I scanned it with VagCom and the check engine error is:
P1606 - 35-00 - -
Now, my ABS light is also turned on... Do you think that it might have to do with the module? From previous posts, I read that I should check fuse #7, 10, 13, which I did, they're fine. Also, I cannot read the ABS codes, it fails everytime.
Also, if I have to rebuild I read that ModuleMaster does quite a fine job. Any opinions? Thanks guys, any help is MUCH appreciated.
Old Dec 23, 2007 | 10:01 PM
hiwords's Avatar
Default RE: What does this code mean? 18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfuncti
probably the module. take it apart and check it out. be careful because it's covered with electrical jelly, don't go washing it off lol
DtTall
Jul 15, 2011 10:35 AM
chris
Dec 1, 2008 11:49 AM
dljking
Nov 30, 2007 02:20 PM
