What kind of lowering is better?
Old Jul 12, 2006 | 01:26 AM
MJ23AIRMW's Avatar
Default What kind of lowering is better?
Hey i want to lower my ride. i really would like to get suspension that i can adjust..
But just wanted to get your opinion.. What should i do.. go with adjustables or just lower with some coilovers?..
Is the only differents between the too, the adjusting part?..
Old Jul 12, 2006 | 01:29 AM
ZedEx's Avatar
Default RE: What kind of lowering is better?
If you lower with coilovers on stock shocks you're going to bounce around like a ricer. If you're going to go lower, DO IT RIGHT!
Get some adjustable shocks (I recommend Koni Yellows), and get some coilovers, or lower springs of some kind. But keep in mind, the lower you go, the more negative camber you're going to have, and that will cause your tires to wear unevenly, and much faster. I'd recommend you buy a camber kit for the front and rear as well. The car will look much better from an aesthetic standpoint, and you will have done it right, so the car will handle MUCH better over stock.
If you're going to modify your suspension, do it correctly.
Old Jul 12, 2006 | 01:32 AM
trailboss's Avatar
coilovers man if you want adjustability. I thought people just called the springs or coil not coilovers like the adjustable strut/spring combo. And the only camber kit you can get is fully adjustable control arms.
flyinb501's Avatar
Go with some coilovers if you want adjustability. I haven't had any camber issues on either of my lowered A4's.
Old Jul 12, 2006 | 01:36 AM
trailboss's Avatar
ORIGINAL: flyinb501
Yea, either have I and im going on at least 15K on the tire i have now and they had 15k when i had them and my front camber is -1.0-1.5
GangStarr_420
Jun 30, 2008 06:47 PM
GreekTT
Mar 27, 2008 05:56 AM
corvetteauto
May 18, 2007 03:52 PM
mark80scu
Apr 13, 2007 08:07 PM
oscarsaca
Jul 3, 2006 09:16 AM
