What Kind of Maintnence?
MAF $90 remanufactured part only
Wheel Bearing $60 new On drive wheels you need a press.
O2 sensor $150 new
My MAF went at 87K mi.
A wheel bearing may go ever 40K mi. All 4 might go in 160K mi.
My O2 sensor is still good at 96K mi.
O2 sensor $150 new
please do more looking for your parts. other than the MAF, most of these parts can be fore for cheap for the same quality, if not better.
O2's can be found for $50. i don't have the site right now, but i'l look. You can redo your entire front end control arms and tierods for under 400
i have an '00 1.8T w/ 104k miles ... be prepared for maintenance! I've done all of the above, plus ...
belt tensioners
fan clutch
secondary cooling fan
secondary air pump
... and now my rear differential is leaking, but hopefully that'll stay together awhile longer.
belt tensioners
fan clutch
secondary air pump
