What is this NOISE!? RESOLVED!
Old Sep 20, 2007 | 11:27 PM
  #31
auditech79's Avatar
Default RE: What is this NOISE!? (Video/sound clip)
No, i thought you had an 01 engine for a minute, its for the variable valve timing.
Go ahead and skip to step 2 then and check the oil pressure when you can.
Old Sep 20, 2007 | 11:30 PM
  #32
onepoint8tee's Avatar
ORIGINAL: auditech79
Ill have to buy a gauge tomorrow. Thanks for the help so far. What are good oil pressure #'s at 2 and 4k rpm's?
Old Sep 20, 2007 | 11:34 PM
  #33
acetrebo's Avatar
I wonder if the fluttering noise I was showing you the one day is a cam chain noise! Thanks for starting this thread, it gave me some things to look at as well!
Old Sep 20, 2007 | 11:42 PM
  #34
ORIGINAL: acetrebo
I dont know, but at least your fluttering noise doesnt make your engine sound like a pos! Sounds like there are marbles bouncing around in my intake mani [&:]
Im going to try to get a sound clip again from my laptop/mic just to see if I can pick up on it better.
Old Sep 20, 2007 | 11:44 PM
  #35
auditech79's Avatar
This is from the repair manual.
Check oil pressure
Disconnect wire from oil pressure switch.
Remove oil pressure switch and screw in oil pressure tester -VAG1342-.
Thread oil pressure switch -2- into -VAG1342-.
Start engine (engine oil temperature approx. 80°C).
l
Oil pressure at idling speed: at least 1.0 bar
l
Oil pressure at 3000 rpm: 3.5 to 4.5 bar
If specified values are not attained:
Pressure relief valve or oil pump faulty, replace oil pump →Chapter.
Old Sep 20, 2007 | 11:47 PM
  #36
The Bishop's Avatar
This isn't the area you are talking about, butI had a wierd noise kindof like that, that I had a hard time locating, also sounded like the intake mani. It turns out it was 2 loosend nuts on my exhaust manifold, when I would rev it the heat closed up the gap.
Just though I'd give my 2 cents.
Old Sep 20, 2007 | 11:48 PM
  #37
auditech79's Avatar
ORIGINAL: thebishop
Also possible.
Old Sep 21, 2007 | 12:15 AM
  #38
ORIGINAL: kextyn
Just a suggestion, but next time I suggest recording just audio with something other than a video camera (maybe a laptop with a mic or something)
Much better (You can really hear it clearly towards the end when I was holding the mic right under the throtle body area, but it still seems to stem from under the valve cover. Sorry for the muffled mic, I was moving it around to different spots on the engine, this is anuncompressed mp3:
Link
Old Sep 21, 2007 | 12:19 AM
  #39
auditech79's Avatar
Sounds like a cam chain tensioner [8D]
Definately check the oil pressure now, and pull the valve cover for cam lobe/bearing wear.
Old Sep 21, 2007 | 12:28 AM
  #40
If a cam chain tensioner is bad can it cause lobe/bearing wear? Ill try to get a gauge tomorrow and test it before I change my oil/go to the track.
